Results 1 to 8 of 8
Thread: Windshield washer pump
    Sep 2009
    Hermon
    91
    Default Windshield washer pump
    I have no power to washer pump. When I push the button to operate I hear a clicking noise and the lower set of runnings comes on each time I push the button. Could the blinker assembly be shorting out and need replacing? Rick
    I've never had the turn signal stalk apart, but with the multi-function set up (courtesy light blink, wiper, turn signal, and washer) there is a lot going on in there so there could be an internal problem. But are you sure you are pushing the right button? On the stalk there is a button on the end to flash the parking lights and that clicking is likely a relay in the electric box beneath the window. The windshield washer actuator is actually the inner ring and that needs to be pushed to initiate the washer function. The inner ring is like a shoulder you would push and not a button on the end of the stalk.
    Sep 2009
    Hermon
    91
    Problem solved!! Thank you Jon
    Feb 2010
    Kansas City, MO
    497
    Holy Crap......It appears that there has been a correct answer posted. Rumors are always floating around about this happening.
    Congratulations, Jon
    Now can I have Maddie??????
    Gary Stevens won't give me his pups.
    Feb 2010
    Kansas City, MO
    497
    Maddie, is high maintenance and as her parents we should probably have a financial statement.
    Sep 2019
    Guilford
    44
    LOL, Thank You Jon
    1,047
    Thank you! Fixing my pump was on my long list of unresolved items. Cant wait to see if this works.
