Here's a block diagram of the installation that I just performed on my bus:
As I mentioned in my previous post these power supplies can produce 1200 watts if fed a diet of 240 volts!!!
So I will be adding another set of power supplies that are driven from my diesel generator, so in this instance the block diagram would be:
Ultimately I will have an automation that will go hey it's 7PM, how's the state of charge for the house batteries? Hey it's a little low, need to run the generator for 20 minutes...
I also found a service where you give it your geographic coordinates and it will predict your solar production for the day, based on the weather forecast and cloud based AI that uses the latest cubesat imaging.
