Solar Simulator, inexpensive AC charger
The answer to my dilemma is inexpensive surplus HP server power supplies!!!
HP for over a decade has had standardized redundant power supplies in their server product line.
As these server’s age; they get recycled for new more powerful servers in data centers and then get stripped for parts to sell.
Given this these power supplies get sold for around $20.00 apiece. The primary market for these recycled power supplies is to power GPU’s for Bitcoin miners.
Another is for radio-controlled (RC) hobbyist to power lithium battery charge controllers to charge multiple batteries for model airplanes and helicopters.
One of the limitations of these power supplies is that the 12V output is tied to a common ground so if you want to use multiple power supplies in series for more voltage; you need to convert them to floating ground so they don’t short out when connected together.
The following link gives background and technical details for how you do this by drilling out a couple of ground studs and replacing with them with nylon bolts.
https://www.youtube.com/watch?v=_2QFBE6ZFF0&t=459s
However, when you are talking drilling with electronics, the resulting metal fragments and electricity that run on; doesn’t mix too well; so you must be very, very careful and understand what you are doing!!!!
Back to your solar charge controllers which you will use as a smart interface to your house battery system.
These controllers generally need an input source that is at least a few volts higher than the voltage of your house batteries. Their primary function is to convert power from a higher voltage source down to the house battery voltage. So to reach the voltage level of a typical solar panel you will need multiple supplies.
In my case I have a couple of Victron 150/70 MPPT charge controller which mean they can handle up to 150 volts input and output up to 70 AMP’s out to the 24V house battery bank. (Note I will use four 12V power supplies which I will explain later.)
Given clouds, time of day. The input voltage can vary, hence the advanced (MPPTT) multiple power point tracking functionality of the solar charge controllers.
Ok, how do you process these multiple power supplies to floating ground without drilling them as it shows in the video?
I came up with a much simple procedure using a rivnut tool, so it only takes about five minutes for each power supply conversion without the need to do any drilling!!!
More to come and hey I am spending a lot more time describing this to you, than it actually took to do!!!
