My bus was converted about 40 years ago and it has two stainless steel tanks one for fresh water and the other as the combined grey/black tank.
In my reading most RV tank sensors are of the conductive type where they detect the level through current flow through the liquid.
In looking at my black/grey tank I see the following wiring:
As you can see there is two wires going to each sensor, what type of sensor do you think it is? Is it a float sensor?
My water tank is up front:
And on the back side of the tank it seems to have the four sensors:
Which I think are of the current flow type.
There was wires hanging loose that I moved out of the way to take the previous picture. Here's a picture of the wires hanging and not connected to anything at this location.
Stuffed in a bag I found a JRV Micro Monitor. In looking at the diagram there's a little combiner that converts the multiple sensors on each tank to a single signal line back to the monitor.
It looks like the monitor would have come with three combiners and two of them appear unused; with one of them in the disconnected wiring mess near the fresh water tank. Which leads me to believe that the monitor was only used for the fresh water tank.
Looking for feedback/advice here as to figuring out what I have here and how to test the sensors.
Thanks
