Have been chasing a leak above the passengers side trapezoid window for over a year. I have removed some of the interior side panels and see a small drip coming from a L shape stainless steel bracket that is part of the Prevost frame and is ABOVE the out side drip rail.
Over a year period I have removed everything from the front cap and dugout the seams on the front cap and resealed everything. The leak is coming from above the window and above the rivets that are a part of the window frames, as noted also above the exterior drip rail. The only thing I can not completely get to to seal is the back side of the awning mount, which through a process of Elimination must be my leak. Has anyone ever taken the outside awning off the side of the coach? Not sure how to unbolt it let alone deal with removing it (imagine it’s very heavy).
