Results 1 to 10 of 30
Thread: New member ... new to me 2001 Marathon XLVII
    Mar 2020
    Pueblo West
    55
    Default New member ... new to me 2001 Marathon XLVII
    I've had several RVs in the past, included diesel pushers and finally decided to made the move to bus.
    Not being made of money caused me to have a budget, therefore setting the age window fairly strict. After much fit/finish research online and in person, I decided on which converter I was going to buy. After much looking and having a particular floor plan in mind, I finally found the coach.
    It was 800 miles away. I flew down to look at for nearly a day. Totally insufficient, especially when you don't have any idea what you are looking for aside from my isn't this pretty. As recommended elsewhere, I should have paid some qualified dude to check over the coach first. Being much more informed may/may not have changed my decision, but would at least have been informed...which is always good.
    I asked the seller, a prominent consignor, a bunch of questions in silly hopes I'd get honest answers rather than typical used-car salesmenship. I showed up for the final walkthru/purchase and a few issues still raised my eyebrows, but on the whole I wanted the coach, so I closed the deal. Now, don't get me wrong, the coach is not a nightmare and being a 2001 I fully expected to have a few things to resolve.
    So, I have a few questions about the things I need to resolve. I've look and haven't found exactly my issues already posted so here it goes.
    1. The coach has 3 Cruisairs. The galley unit seems to cool just fine, however it doesn't activate the aux heat. The control is set using the double-tab and the heat indicator blinks and when the temperature is reached, the heat indicator lights but I don't hear any relay and neither the Wabesto heat nor cadet will run. Breakers are good. The 12V and 110V heat are on in the closet as the other two units work fine. I swapped control panels with another unit with no difference. If I activate the manual mode on the techlink module under the sink for the galley heat, the Wabesto fan will run. So it seems like the there is no relay telling the techlink to charge the Wabesto relay. Where should I look next? Is there something on the Cruisair unit itself that could be checked/reset? If I have both the 110V heat and 12V heat buttons on, is both the Wabesto AND cadet heat supposed to run at the same time?
    2. When buying the coach, the step cover would not operator properly. They replaced the piston that extends the cover. But, I think it now has an air leak. If I leave the step cover retracted, I can hear the air leak. If the step cover is extended, I don't hear any air. Haven't tried to get to the bottom of it, but it does tend to drain the aux air tank fairly quick. Speaking of aux air tank ... can one of you confirm my understanding: Front and Rear air tanks are for the break system. The Aux is used for the pocket door, step, and ride height/leveling. Do I have that right?
    3. I think I have a curbside rear air leak of some sort, unless somehow it is related to the step cover causing the aux air tank to drain. I am leaving the step cover extended overnight to see if the coach leans over overnight. It has with the step cover retracted. As I said, could be totally unrelated as I thought the air bags shouldn't let air back out once in unless the bag itself is leaking or the valve is leaking/defective.
    4. I'm fairly sure the 6 4D batteries need replacing. I can only be without power for about 2 to 4 hours before the generator is started. Where is the best place/price to get them replaced. Those suckers are a bit expensive and look to be a little bit of PITA to change out.
    5. A previous owner swapped out the TVs and appears to have abandoned the techlink monitoring at the front drop down TV and the dash. The dash monitor was replaced with a Kenwood system that has the backup camera, but didn't attempt to hook up the techlink on another video source. So a little fiddling around with that to make it whole. They must have an uncapped coax or some cable around the a power supply because I am getting a lot of interference in the bedroom view of techlink screens. So I've got to track that down to get a clean picture.
    I'm sure there is more I'm missing, and have yet to find. Even with these issues, I'm happy to join the ranks of Prevost ownership. It is much like the large boats I've had in the past...another money pit. But like the boats, I plan to enjoy the heck out of it and make it better than I got it. These are not issues, they are opportunities.
    Anyway, if you have wisdom or insights on my current list of ... opportunities, please forward them along.
    - Terry
    3,782
    Terry,
    You likely have (6) 4DL batteries, contact me for a great price on Lifeline Batteries. I can have you batteries in a couple days.
    Hey Terry congratulations and welcome to the asylum. Let me try to help you with your lean. Whatever corner it's leaning to the left rear or the right rear the The fenders hinge up there's Clips all the way at the bottom before the drive axle and after the tag axle release them flip the Thunders up and find the air tank that is associated with each airbag the front airbag air tank is Forwar of the airbag behind the shock and the ride height valve the tag bag air tank is very easily visible hanging off the outside of the frame rail the air tank for the rear-drive bag is tucked inside the frame rail but if you look you can see it without too much effort soap up all those drains on those air tanks and see if that's your leak often times it is and it's a very quick and inexpensive repair either replace them with new drains or plug them as I do all of them. You'll never get moisture to that point in the chassis even if the air dryer hasn't been serviced correctly but that's your call hope this helps.
    Mar 2020
    Pueblo West
    55
    Terry,
    Yeah, there are (6) LIFELINE GPL-4DL AGM batteries. Round circle sticker says DN ... so is that April 2014?
    Barring running electric heat/water heater, how long is typical for the coach to run on the batteries before needing to recharge?
    Last edited by TerryCurtis; 03-23-2020 at 09:30 AM. Reason: Updated date code on battery
    Mar 2020
    Pueblo West
    55
    Tom, are you able to provide a quote for 6 batteries (presumably from the same batch)?
    Is this really something I should be doing myself or have them shipped to a qualified installer?
    Is there a list of favorite/trusted folks that install them?
    Are there gotchyas in doing it with all the electronics going on in a Marathon so it doesn't die ;-)
    Terry,
    Indio
    589
    I found that the price of the raw batteries, compared to the price of having someone else install them was worth letting someone else deal with it.
    They are very heavy and easy to melt a socket set or end wrench by touching the wrong thing. I have a few melted tools to show for it.
    Can you do it yourself? Sure. But it wasn't worth the $400 difference to me.
    As for the Marathon, you'll have to power down everything.
    3,782
    Terry,
    Your price for 4DL’s would be 548.00 each plus shipping. Lifeline Battery inventories are at an all time low, some sizes not available for 2 -3 weeks. 4DL’s were still in stock yesterday, but at a low level, so don’t wait long if you want to order. Contact me here: Lifeline
    Marathon did not do a great job of wiring or mounting the house batteries in most models. Yours may well be in the small bay behind the tag. If so, they are best wired as they are each installed. It's best done with 2 people for the angle mounted batteries. Marathon for some odd reason must not understand the value of bussbars. Instead they stack a lot of cables on one battery terminal. I'd change that.
    If your batteries are on the driver's side, they are easily changed.
    Mar 2020
    Pueblo West
    55
    Gil, that's exactly how these are mounted, behind the tag, angled, a spiderweb of wiring with very little clearance. I am extremely hesitant to do it myself. It may well be a valuable insurance policy to pay Marathon to do it, however it will be costly...but maybe less costly than me frying the coach electronics.
    Congrats on the purchase. Sorry to hear it wasn't well represented.
    Reply: Yes, both 12 and 120 volt heat will work together. I believe the TechLink interface is mounted on or next to the SMX/CruiseAir control box. Although this doesn't sound like the problem, the cadet heaters are activated by motorized circuit breakers in the main circuit breaker panels, which you likely have a few.
    Reply: If you are hearing air leak in one direction of the step well slide, it's likely the ram. That would seem strange if it was just replaced. BTW, most of those rams are a PITA to get to.
    You have 4 air systems. On the Prevost side there's the front and rear braking systems and Prevost auxiliary for the suspension, engine air bags, and little else. Then there's Marathon auxiliary air for everything Marathon air. Most converters combine Prevost and converter aux air systems. Marathon typically does not. Go to the bay under the driver's seat. On the right side wall you should find an air valve with maybe a yellow handle. Marathon generally attached a tag reading to leave off unless the Marathon aux compressor failed.
    Reply: Suspension leaks are unrelated to any other leaks. Raise the tag, level the coach, and see if it still leans. This will help you determine whether its tag or drive axle related. It will be the bags, Norgren air control valves, ping tanks, and/or air fittings.
    Reply: What is on? Air conditioners? If they are Lifelines, check for a 1" or so round sticker on the side. It will have the month and year represented by 2 letters. As much as the cost, if they are less than about 5 years old is to have them tested.
    Also, someone may have set the AGS trigger voltage higher than it needs to be. This would cause early generator starting.
    Yes, there is likely 6 4D batteries and if they are in the bay in front of the engine yes they are a PITA to replaced.
    Reply: Many abandon Crestron control of new TVs because of the cost of reprogramming the Crestron system.
    Does over the air tuning work? From the factory it would have had a remote tuner that in 01 was probably not capable of ATSC (digital) tuning.
    The TeckLink video distribution amp is likely under the bed. The TechLink video switch for the dash should be in the dash near the radio.
    Joe Camper will likely respond. You should have him visit you and go through the chassis. There's no one better.
