Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Advanced Search
    Ray, your the computer expert, but I keyed in guest charger and got 26 posts with about as much guest charger information as I could stand.
    I don't get it.. What do you want it to do?
    Out of how many incorrect threads? I just did exactly the same search, it comes up with 100 threads. Clicking through each of the top 10 threads, not one was about Guest Chargers. They all had the word charger in the thread, but not guest, nor guest charger.
    I want to be able to search with more than a single word, and get a result which is limited to posts (or threads) which contain both words. Yes, I was able to find the thread I needed ultimately, but only after sifting through 15-20 threads which had nothing to do with guest charger.
    Perhaps since you are an administrator, your search function is different than regular accounts? Maybe that's why we're seeing different results?
    Hmmm,
    I'll defer this one to Skiffer!
    Adding a tag or tags under the Add/Edit Tags button (lower right when you post a reply or add a thread) will help in the search process.
    (Yes that's me I was test some things!)
    Jim
    Absolutely. Bad news is a large amount of our golden nuggets pre-date the time when the tagging capability was added. But, it's certainly a good thing to remember to do that now, even to older posts.
    It's just interesting to me that the older vBulletin software did a much better job searching. I use it on our Pixar support site, and it works very well. Multi-word searches are just not functional here for me.
    Jeff Bailey had the right idea but to compile the information that is posted it is going to take a team of folks to go through all the posts and cut and paste the golden nuggets.
    In between all the horseplay and unrelated remarks this site has a substantial amount of information about dealing with problems, sources for information or parts as well as personal experiences. There are more than enough active members on POG to be able to distribute the responsibility for various categories or threads to make relatively quick work to create a document that can be kept up to date and which could serve as the POG reference book.
    But to pull it together someone with the skills necessary to herd cats needs to take control.
    Mar 2010
    Scottsdale
    85
    The key problem is the software that runs this site. It's a package known as vBulletin, which I also use on my ham radio website. Frankly stated, vBulletin's search capabilities stink.
    I solved this problem on my site by letting Google search the site. The Google search engine can find things that vBulletin can't even attempt. My site has 400,000 members and over a million posts, so some sort of indexing was a must.
    To make it possible for Google to do the search, you have to give Google the equivalent of a user account so that it's engine can browse the site. Even though some things can then be found by non-members, they still can't visit the site without being members. It works well.
    -fred
    Dec 2005
    Newcastle, Maine
    772
    Thanks Ray, Jon & Fred.
    I'll see what I can do about getting the Google Search Feature.
    Jim
    Apr 2008
    no where
    439
    Jim,
    I would like to raise a caution about using google search. I would not want a lot of the information we post on POG to "leak out" via google. Over time we have posted address, phone numbers, who is traveling, etc. Having a closed system provides us some protection from "unknown" internet users. Using google search may allow anyone to see some of this information. I do not know this for a fact, but please check with your web guru before opening up to google.
    While the Google search feature may enable someone to find something they know is on one of the posts, having a reference document will be worth its weight in carbon emissions.
    For a relatively inexperienced owner a single readible document with the collected wisdom in the form of links, articles, and personal experiences will be so much more valuable than having the ability to do a Google search it will boggle the mind. Most of us haven't a clue about something unless we hear about it from someone, or experience it ourselves. When we are less experienced we don't even know what questions to ask or what information we should know. What good is doing a Google search if we don't know what we are looking for? After having gone through the experience of learning about stuff only after something broke, I know I would have benefitted highly from having a listing of things POG members consider worth knowing and including in a reference. Look at a lot of the posts that originate because an owner has a problem, and consider how many of those problems we able to be prevented if the owner knew what others have learned through experience. When Michael couldn't get his coach to come to driving height he could have found the reason and in most cases, Michael's included, there are usually subtle clues that precede most failures. Wouldn't it be great if every owner knew from this reference document that the battery life is controlled by how the inverters are set up for charging? It certainly would be better to scan a document and see a reference to batteries or inverters and learn how the two relate, and not find out until after cooking a $2500 set of batteries.
    Let me cite a few examples. How many times have we seen folks start chasing problems with the "leans" by starting with their auxiliary air compressor? If a new owner hasn't run across posts or threads relating to the leans it is completely within reason for that owner to focus on the loss of air pressure. I know, I see the emails and PMs asking about that.
    Until someone starts experiencing overheating problems how many owners even consider that unlike cars our engine coolant and its maintenance is a major contributor to our engine's health? We have some great indepth discussions about coolant, types, and the underlying reasons for maintaining the coolant. Until an owner experiences problems most give no consideration to coolant changes, but if as part of our reference document there is a topic about coolant maintenance, an owner not only has the data and sources, he is made aware this is a topic he needs to know. Google certaily isn't going to make him think about it, until he does the Google search on overheating and finds the related posts and links. When the bus is overheating it's too late to start maintaining coolant.
    There are many other examples but suffice it to say if we create a reference document, an index, or some single source point to find information just the listing of available information is going to arouse interest and allow and owner to fill in gaps of knowledge he likely wasn't even aware he had.
    I'd also be willing to be that even those of us who are really comfortable with our knowledge of the coach would like to review certain topics just to make sure we still understand the subject and need to keep it in the back of our mind.
    Just my brain dump for today.
    Jeff Bayley Guest
    I guess I missed this entire thread from before and happened across it. Regarding compiling the information within, if the idea of combing the site for past posts seems to exhaustive of an under taking, what about at least starting from this point forward and begin taking the meat of informative threads and start compiling ? If we never went back and found the old info then a year from now we would have the making of a good additional resource. If we could lay the foundation, maybe members would browse through it and could at least remember their own meaningful posts and go back and find them to append the reference material. With the current Advanced Search not giving results however, it would be hard for most of the regular contributors to even find their own posts that are more than a few months old. Being able to search the site effectively is essential to putting the master document together unless everyone wants to recreate their content all over again. Can Truk or Skiff tell what became of the Google Search suggestion ?
