Grote also makes a 24v lamp with a standard wire connector that does not require a special pigtail, and you're right - the chrome branch deflector won't fit but, you can use the existing mounting holes and wire connector that Prevost uses. I just went around the (white) base with black plastic edge molding. I'll post a picture for you in the AM.
