Results 1 to 10 of 12
Thread: Genset leaks
    Battle Ground, WA
    851
    Default Genset leaks
    Just discovered our Powertech 17.5 (Kubota) is leaking from 2 freezeplugs. Luckily I have the previous Prevost Mtc invoices and it shows two were replaced in '05. Have a call in to the previous owner to find out why. Spoke to my generator expert at Wrico Intl. and was told the Kubota will not accept generic freeze plugs, they don't fit. Just another "gottcha" to look out for from Prevost Mtc.
    Question: Seems like a good time to flush the coolant system. What's the best procedure and flushing product?
    Thanks.
    Brian,
    I've never flushed the generator cooling system (or bus for that matter except for refilling with water and redraining) but I suspect each generator cooling system is different enough to use different methods.
    My experience is limited to Liberty and as you know they have drain plugs on the copper pipes at the low point between the remote radiator and the generator. I drain there and fill at the radiator using a funnel I hang higher than the radiator cap somewhere on the arms of the bay door. I bleed air from the generator by opening the cap on the generator itself.
    The Kubota on the first coach was much easier to fill and bleed compared to the Yanmar on this coach. The Yanmar is very difficult for me to burp the air bubbles out of it, although running it for a few minutes and filling at the generator cap seems to do it after about 5 tries. As to why I do not flush (I presume you mean using chemicals) it is because both my generators ran on the cool side. I never had an indication of temperatures beyond 170 to 180.
    Why would a soft plug need to be replaced? I'll bet it has been 40 years since I dealt with a freeze plug replacement.
    I treat the coolant in the gen just as the 8-V low silicone with additives and test strips.
    3,783
    Joe,
    Why? They don't have wet liners to they?
    Tom I'm not sure.
    Battle Ground, WA
    851
    Jon, I've never used a chemical flush either and probably won't unless someone here recommends it. Am also curious about the plug replacement and have a call in to the previous owner of the bus.
    Joe, Am not sure if it's a wet sleeve engine. Thought I'd try the brain trust before calling Kubota. Will report back.
    Aug 2007
    Grass Valley
    480
    A little thread creep on a near subject. After a recent coolant drain and re-fill with CDL coolant I had the bus out this past weekend. I ran the webasto for 30-40 minutes on two mornings. When I got ready to head home the dreaded check engine light was on red. I checked oil, transmission fluid and made my way to the engine water holding tank. Luckily I had three gallons of the new antifreeze on board and it took all three to fill the system. Evidently the webasto water system had a huge bubble in it that did not show up until I ran it. We ran the engine on the road after the coolant change and added more fluid. I even ran the webasto for a short spell at that time and the bubble stayed in the system until this later date. All ended well.
    Brian I think you have the answer to your Gen Set scoped out. Good Luck.
    Harry
    Judi Brown Guest
    Default 91 Liberty H3 40
    Our gen. runs to hot and my husband is thinking of putting elec. fan on from 1 of those japan cars. Has any 1 tried this.
    JB
    Battle Ground, WA
    851
    Judi,
    Not sure about a '91 but my '94 Liberty had a large electric blower as part of the system. If this blower is installed in your coach, the genset won't run without it running also. Would look elsewhere for overheat problems such as clogged radiator, poor airflow due to dirty vent openings, etc.
    Battle Ground, WA
    851
    Harry, Had exactly the same experience when I drained and refilled the Liberty with Extended Life Coolant (ELC). There is a small purge valve installed at the high point in the Webasto system. Usually near the driver's AC evaporator, behind the grate at the top of the entrance steps. Running the Webasto with this valve depressed (Schrader) helps but the system still seems to retain a lot of air until the engine has run for awhile.
  1. Kubota Genset
    By Journeyone144 in forum Ah Houston, I think we have a problem...
    Last Post: 05-24-2010, 10:47 PM
  2. Genset Radiator Rusted Out!
    By michaeldterry in forum Ah Houston, I think we have a problem...
    Last Post: 02-20-2010, 11:00 PM
  3. No More leaks?
    By dreamchasers in forum Country Coach
    Last Post: 10-12-2009, 06:08 PM
  4. Powertech Genset
    By grantracy in forum Busted Knuckles and Greasy Jeans
    Last Post: 04-15-2008, 09:53 AM
  5. Home Genset
    By Just Plain Jeff in forum MISCELLANEOUS ITEMS
    Last Post: 10-30-2007, 11:52 AM
