Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Warning: Always leave gen auto-start on
    Ours has a 12 volt equalizer switch in the control panel that ties the gen and 12 volt house batteries togeather.
    We also have a 24 volt equalizer switch to tie the bus and the house (4 each) togeather as well. Going down the road with the 24 switch on the alternater charges both house banks, 12 and 24. They work the other way as well, we can use these switches to jump start the bus and gen. both, if nessesary.
    If we leave the 12 volt switch on with the gen. running the 12 volt house batteries get charged by the gen alternater.
    Ben Guest
    Truk,
    Even more important... don't leave the auto-start on while changing the generator's oil!
    The coach smells fine after a good shampoo job... they cleaned the entire coach... all I needed was the spot below the fridge. No charge for the service either.
    -Ben
    Glad it all worked out Ben and thanks for the heads up...
  1. Testing Auto Start Function
    By grantracy in forum Sparky's Corner
    Last Post: 03-08-2008, 11:07 PM
  2. auto start...
    Last Post: 12-13-2007, 05:07 PM
  3. Triggering Auto Start Function
    Last Post: 11-30-2007, 01:15 PM
  4. Gen Set Auto Start
    By bluevost in forum Engines, transmissions, axles and wheels
    Last Post: 06-27-2007, 11:23 PM
  5. Gen Con / Auto Start manual needed
    Last Post: 10-29-2006, 08:20 AM
