Results 1 to 10 of 10
Thread: Looking for air leak
    Sep 2020
    GARLAND
    93
    Default Looking for air leak
    The left side of my 2000 CC XL (1999 chassis) is leaking down on the left rear side. I took it to Luxury coach in Rockwall. I provided the two Norgren air valves that bolt on to the crossmember for them to install. After the installation of the valves and 17 fittings I still have the LR losing air.
    Any suggestions where to go from here?
    If I drive up on wooden ramps do I need to raise my tag axle?
    Thanks,
    Norman Martin
    2000 CC 60408
    1,053
    Norman: Assuming that the new valve on the LR side is not leaking internally and that the new fittings on that valve are not leaking, then it is likely the fittings on the bags or the bags themselves.
    Luxury Coach has a new manager and Brandon of Legacy Coach is the new owner. I would call them, explain the situation and ask them what they are going to do. Based on my experience, they will take care of you.
    Keep me posted.
    Sep 2020
    GARLAND
    93
    Ok Mark, thanks for the information. I live about 10 minutes from them in Rockwall County. I'll give them a call.
    Norman
    Dec 2012
    McKinney
    65
    They do great work. Dodie is still working 3 days a week and has great things to say about the new manager, Todd, who was hired from Prevost Houston.
    Sep 2020
    GARLAND
    93
    I was hoping that changing the Norgren valves and 17 fittings would fix the problem, but it didn't.
    Norman Martin
    2000 CC XL 60408
    990
    There are hundreds of leak points, best is to get under the bus with soapy water in a squirt bottle and start soaking everything.
    Dec 2019
    Brodheadsville
    322
    Norman, Hopefully you located the leak. I can tell you this much. If you replaced both Norgen valves at the rear and the LR is still leaning then There are only two possibilities remaining. 1:The airline from the valve has a leak maybe from rubbing on the chassis or at the fitting on the air bag. 2: the air bag has a leak. The airbag would be my target. If you have jack stands you can inflate the rear bags as far as they will go exposing the entire bag, get under the coach and blast the entire bag with soapy water. I have also seen the threaded fitting coming out of the top of the airbag where the airline connects, get cracked. Check the tag axle bag also.
    Let us know how you make out.
    1995 Liberty XL
    Chris & Sara Jo Behrens
    Sep 2020
    GARLAND
    93
    I was told that one of the Norgren valves in the front compartment under that driver can make the coach lean. It will not show a leak at the valve. I guess I’ll have to look into that too. I have some ramps that I can drive the rear of the coach on but I wonder if I need to raise the tag axle or just let it hang. Anyone know about that?
    thanks,
    Norman Martin
    2000 CC XL
    Dec 2021
    Hillside
    124
    Hey Norman,
    I have mine on ramps quite a bit and never had a cause to raise the tag....you should be fine
    Jerry & Pam
    1993 Marathon XL40
    2021 Jeep Wrangler
    1,053
    Norman: In order for your bus to lean, the rear air bags have to loose air. I have not looked at your specific bus air diagrams. However, it is my understanding that if the ignition is off, then the rear norgrens disconnect from the air source internally. Therefore what ever air is in the bags is trapped between the bag and the norgren. If the key is on, then the rear norgrens are connected to the the ones in the drivers compartment. In that case, the front valves can leak air. So If your bus in leaning with the key off, then in my experience, it has to be the rear bags, the fittings, the tubing, or the rear norgrens. Everything else is out of the picture when the key is off. That said, I suppose that if the drive control valve in the 5 stack was leaking air to the rear norgren control, it might not move fully to the "parked" position but I have never heard of that.
