Results 1 to 3 of 3
Thread: TST Tire monitor system
    Dec 2020
    Goldsboro
    174
    Default TST Tire monitor system
    Experience witg a TST system and reading the toad tires. Do you have a repeater for system if monitoring toad tires also?
    George and Joan
    2006 Royale March 2024
    Goldsboro NC
    2022 Ford King Ranch
    I have the TST system to monitor all 12 tires (8 bus, 4 toad). You need the repeater so you get good signal from the toad tires. I installed mine in the rear side compartment above the chassis batteries.
    Rich Plaskon & Kyle Bloch
    2006 Country Coach XLII
    2015 Jeep Cherokee Trailhawk
    930
    Same for me. As far as I know, TST sells the base system now complete with the repeater. The repeater is 12VDC. I also installed it in a side bay. The passenger side just in front of the drive wheels. I had a 120 VAC receptacle in that bay and just used a small 120VAC to 12VDC converter to power the repeater.
    Used the system for the first time going to POG Michigan and it worked flawlessly for the month that we were out.
