HI. has anyone had a slow freon leak in the dash air. I have added dye and sniffed everything I can reach. still losing freon each season some times twice in a summer. all comments will be read. thanks. TERRY.
Friend had a small leak in the dash air that he chased for almost a year. Turns out it was a slow leak on the compressor shaft seal. Found it by using a ultraviolet light and saw small speckles all around the compressor clutch.
Chuck & Katrina
2000 Featherlite
H3-45 Double slide
GOOD info. will follow that one. compressor was replaced by marathon prior to my ownership. thank you
Dye was installed in the system and provided the speckles by the compressor clutch that could be seen by the UV light. Sniffer never indicated a leak at the seal and dye was not enough to see without the UV light.
Chuck & Katrina
2000 Featherlite
H3-45 Double slide
