Results 1 to 6 of 6
Thread: CruiseAir acting up
    544
    Default CruiseAir acting up
    Had forward CruiseAir replaced a couple of years ago, been working like a champ. All of a sudden it starts just blowing hot air and cycling off - on.
    Turns on (Amp Draw 10 Amps), runs 2 minutes blowing hot air then compressor cuts out (but fan still running). After 3 minutes unit completely shuts off. After 3 more minutes unit restarts and cycles again.
    Suspect this indicates low freon, am I correct?
    Chuck & Katrina
    2000 Featherlite
    H3-45 Double slide
    Dec 2019
    Brodheadsville
    254
    Could be low on Freon. You would need to put gauges on the unit to measure pressure. Are any of the lines sweating moisture!
    1995 Liberty XL
    Chris & Sara Jo Behrens
    544
    Havn’t dropped the front bumper to check with gauges or for sweating. Seeing the is no cold air I suspect the would be no sweating.
    Chuck & Katrina
    2000 Featherlite
    H3-45 Double slide
    Jul 2021
    corpus christi
    100
    How do you like your cruise airs in the summer Ck2hans? My bedroom 1 currently freezes me out...my front 2 are shot, I have a gentleman coming out to take a look see and attempt to fix.
    My front 2 cruise airs came this way with purchase....bought her in oct of 2021 so it hasnt been an issue....but summer commeth
    and we bake in south texas.... yeee hawwwwwwww
    544
    Patrick:
    My CruiseAir in the bedroom also freeze us out but the front only moderately cools the coach. Had AAP completely replace the front a few years ago, It defiantly blows cold air (we used to) but just can't keep up with all the glass that allows heat in on the H3.
    One item on my bucket list is to completely disassemble the front area and reinsulate it. Also plan on coating the roof. Guess that's two items for the bucket list.
    Chuck & Katrina
    2000 Featherlite
    H3-45 Double slide
    879
    See I knew it! you do have a list.
    Mike Giboney
    1992 Prevost Country Coach
    #60187
