Page 7 of 7 FirstFirst ... 567
Results 61 to 68 of 68
Thread: Over-the-road air??
  1. #61
    Mar 2021
    Parkland
    12
    My old XLV 1999 #539 Marathon is equipped with OTR and 3 Cruisair units, 2 X 4000w trace inverters, 6x 250ah lithium batteries, we added 2 MPS low profile 24v roof top units, I came out to the conclusion that if I build a new coach I will equip it with only 24v roof top units, maybe 3 or 4 but nothing else. We run 2 all night and our battery bank goes down only about 20%, they are quiet and ultra efficient, hot air goes up not down so conditioning the air is much easier, this is the way they look.
    The question is: why have so many systems? 24v units will run on the engine alternator on batteries, on shore power with the bat charger.. My 2 units are doing a phenomenal job to keep us comfortable, we will be covering our roof with solar panels to make it even more interesting. Generator is charging our batteries in a record time..
    We changed out refrigerators by dual voltage 24v 115v but most of the time they run on 24v..
    Now changing the oil on our generator is not as often.
  2. #62
    Stupid question. Is this possible to do 12v. Im currently in planning stages on redoing the camper side of my pete, from scratch, 1 month away. Its 12 v.
    Nother question what does one cost?
  3. #63
    Mar 2021
    Parkland
    12
  4. #64
    Mar 2021
    Parkland
    12
    We have the MPS 12000 12v on our sprinters service vans, they run at max speed at 45amp, and at low econo night time about 25amp.. I get them for $1200 lel me know how many you want?
  5. #65
    Quote Originally Posted by Mabruteam View Post
    Can you supply a link to these units?
  6. #66
    Mar 2021
    Parkland
    12
  7. #67
    I'm a bit skeptical on the power use for 12KW BTU. Your site suggests 24V systems, but I didn't find any. I would be curious if there is a low profile 24V system and, if so, is there an installation manual? Will it supported ducted systems? The limited specifications suggests its thermostat only displays Celsius. Can that be true?
  8. #68
    964
    That is it! The last of the non functioning AC junk going in the trash. The copper tubing was very soft and thin.
    Mike Giboney
    1992 Prevost Country Coach
    #60187
  1. Removing Road Tar
    Last Post: 11-04-2009, 07:55 AM
  2. Road Warriors
    By win42 in forum MISCELLANEOUS ITEMS
    Last Post: 01-28-2008, 11:30 AM
