Results 21 to 30 of 33
Thread: What TPMS would be the best for my Coach and Toad
    Apr 2018
    Crossville
    278
    Since I display the tire pressures to our Crestron iPad monitors and not a smart phone app, I only needed the Pulse and not the Pulse FX. I have been happy with it.
    Apr 2014
    Tyler
    84
    Les,
    Thank you for your reply. The information you provided was very helpful. Trying to decide between the Pulse and FX. Wanting to utilize the Crestron with the PressurePro.
    Reese
    Apr 2018
    Crossville
    278
    With the Crestron smart phone app, I can display the Pressure Pro screen. While driving I usually have Waze running on my cell phone (in addition to the dash built in Garmin RV770) so the phone is "occupied".
    Apr 2014
    Tyler
    84
    Les,
    Thank you again for your reply. I believe that you answered my question, but I have a stupid question. Where do you have your Pressure Pro Pulse monitored mounted?
    Reese
    Apr 2018
    Crossville
    278
    I made a little bracket and have it near the toll window. That allows me to run the power and remote antenna wires directly down to the steering bay. Since the Crestron display is truly just a display, the PP monitor is the actual control brains. The interface to Crestron has no effect on the Pressure Pro functionality. It will still display and alarm.20191226_104101.jpg
  6. #26
    Apr 2014
    Tyler
    84
    Les,
    Thank you for your patience in dealing with my stupidity. The information that you provided is of tremendous assistance.
    Reese
  7. #27
    3,775
    Reece,
    I believe Les has the 35’ extended antenna that eliminates any loss of signal concerns from the toad. We did a bunch of those with the Pulse since there isn’t a Repeater yet for the newer Dynamic Sensors. The Pulse FX is easier to install since it works on Bluetooth and can be placed anywhere in the coach that assures a good signal from the rear.
  8. #28
    544
    Tom:
    Does the extension antenna from the Pulse work on the Pulse FX?
    Chuck & Katrina
    2000 Featherlite
    H3-45 Double slide
  9. #29
    3,775
    Yes, same connector.
  10. #30
    Tom,
    Is there some reason why the wireless Echo Repeater isn't used or recommended. Although wired should be better, 35' is a long cable to snake to the back of the coach and it would still probably only get you just rear of mid coach.
Tags for this Thread
