Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Water Heater Leak
    871
    Yesterday, I had to vacuum the sediment out of both water heater tanks, flush with fresh water for about 15 mins, then vacuum. I did this 4 times for each heater and I think they are pretty clean for 28 years old. The new elements are installed, powered up, and started to heat the water. I only gave them about 15 minutes checking voltages on the heaters, thermostat and cutout, the water didn't have enough time to get hot but it was warmer. I will leave the system pressurized and heaters off overnight to see if there are any leaks before I button it up. I will be glad to put the water system behind me so I can move to the Webasto.
    Mike Giboney
    1992 Prevost Country Coach
    #60187
    Mike, a 30 year old hot water tank that's not leaking or about to leak is pretty impressive.
    871
    Thanks! maybe it was the silt insulation it had on the inside. It has been sitting at 40 psi for almost 24 hours now and no pressure drop yet.
    Mike Giboney
    #60187
