Results 1 to 10 of 16
Thread: High Idle quit
    525
    Default High Idle quit
    Just had all the brake calipers off and finished replacing all the guide pins on the brake calipers. While the coach was still up on jack stands with the wheels off I started the engine and tried to engage the high idle to get the air tanks back up to PSI, nothing happened. Turned off the engine and power switch, turned back on, restarted and still no high idle. Only thing I can think of is the parking brake was set with about 70 PSI in the tanks, maybe it didn't set enough to allow the high idle to engage. Just shooting in the dark here.
    P.S. Darn those brake parts are big, you really realize it when they are off the coach and on the work bench.
    Chuck & Katrina
    2000 Featherlite
    H3-45 Double slide
    Why did u decide u needed or wanted to air it up at that point? To assist in the step of uncaging the chambers?
    Were the parking brake chambers caged?
    If any rotation of the driveshaft was allowed to occur when u started it and it can, even if u r in neutral, if the brakes were not all engaged in the rear. Then the computer thinks the bus is moving and it wont let that happen the high idle I mean. That will also give an antilock code too.
    U should be very satisfied with yourself if u did this it is no small task. Well done mate! U should also be so happy u have drum brakes on the drives. Your signature says 2000 so u have a 99 chassis? Or do u have all 6 hubs disk on that year H? Getting a caliper off the drives on the chassis that have them is easily twice as difficult to get off as the ones on the tag and the steering. Putting them back in place is an absolute artform to learn. Oh ya Gill u should film me doing it for those thingies u do on the innerweb.
    Yes, I'm betting the parking brake was not set.
    Joe, sure buddy I'll make you a movie star!
    The yellow button could have been pushed down too, I suppose but it would have been giving a warning beep. Button up and popped as if parked but brakes were caged that is my guess what occurred. Curious as to what brakes can on a drive axle on a 99 h chassis not sure.
    525
    Joe: Mine is a LATE model year 1998 chassis. I have disk all around and DDC IV, so I guess even though it”s a 1998 I got most of the 1999 model year stuff.
    When picking up parts at Prevost Winter Garden I meet their Southeastern district trainer. He suggested airing up the bus and applying the brakes a few times after the job was finished and before the tires were reinstalled to review and confirm proper operation of the breaks.
    Once the bus is back on the ground and driven do you think there is a chance the high idle will start working again?
    Chuck & Katrina
    2000 Featherlite
    H3-45 Double slide
    I'm curious what tool did u use to remove the bottom slide pin on the drive axle caliper.
