Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: XL Headlight Conversions
    May 2009
    Regina, Sask, Canada
    129
    I havent , but thought the same thing. Not sure if Ill get the chance. Ive got the LED driving lights to go on too so expect it will be quite a difference. Will post a pic if I can on a comparison.
    Craig Lenz
    Yellow Grass, Saskatchewan
    1996 Angola XLV #5688
    Jan 2019
    Bloomsburg
    102
    Good afternoon all, attached are several photos of the headlight conversion from CP addict.com. I too had some issues aligning the headlight in the center of the bezel, however with a prybar, I was able to push them all the way to the outside, which allowed them to fit nearly perfect. Honing out the headlight adjuster holes unfortunately will not help because the bolt travel is a limiting factor. I also experienced the headlight adjusters spinning like someone else had mentioned. Lastly, when you install these into the stock housing, you will need to turn all three adjusters in by at least three turns to gain the appropriate clearance on a liberty.
    F30CE20E-0B89-49BE-986B-372752E67CA9.jpegFE960023-C909-40D3-91DE-0803054ABB16.jpeg7F79DDC5-52C3-4718-98FE-4EE1096E23F3.jpegA30924E2-D98E-438F-A63B-CCB970BE0C2D.jpeg
    Jan 2019
    Bloomsburg
    102
    The evening photos were taken with one LED light and one halogen light. The LED light was so much brighter, It washed out the halogen light.
