Results 1 to 8 of 8
Thread: Tire Markings
    Mar 2013
    Chicago
    3,988
    Default Tire Markings
    If you look at the sidewall on this passenger car tire there's a yellow dot At 12 and there's a red dot at 2. I'm pretty sure I remember being told once that those colored dots on the side walls on passenger tires are there because if you align the dot with the valve stem it will facilitate the least amount of wheel weight necessary to balance the tire. That doesn't explain two dots on the same side wall or the different colors. Does anybody out there have any information and can help clear this up for me?
    1990 Peterbuilt 377
    3406 B Caterpillar
    13 Speed Roadranger
    No Norgrens
    1 day on paper no machines
    Oct 2012
    Smithville
    326
    Yellow is tire sensor position and red is a rough/low spot in the tire
    Mar 2013
    Chicago
    3,988
    Where did u find that info? The red or the yellow gets lined up with the valve stem or no?
    1990 Peterbuilt 377
    3406 B Caterpillar
    13 Speed Roadranger
    No Norgrens
    May 2019
    Box Elder
    36
    Mar 2013
    Chicago
    3,988
    Thanks. The explanation still has me a bit unsure but thanks. In any event the guy who mounted the one in the photo didn't get it right neither dots lineup with the valve stem.
    1990 Peterbuilt 377
    3406 B Caterpillar
    13 Speed Roadranger
    No Norgrens
    May 2012
    Beverly Hills
    4,652
    Straight from a tire manufacturer.
    https://www.yokohamatire.com/tires-1...match-mounting
    Gil and Durlene
    2003 H-3 Hoffman Conversion
    Sep 2019
    Guilford
    44
    Sumatomo Truck tires had a green dot as a balance marker to line up the valve stem. but that was 40 years ago and most tire guys had no odea what it was for.
    Pinehurst
    950
    At least it isn't under inflated like some tires I know!
