Hello,
In my bathroom vanity which runs on AC I have incandescent lights. When replaced with LEDS they blinked. Is there a certain type of LED lamps I need to use?
Thanks!
Hello,
Thanks!
Typically a result of a resistive dimmer or being powered through some inverters.
Gil and Durlene
2003 H-3 Hoffman Conversion
I will echo gils comment. I ran in to this as well, and I had to swap out the dimmer switches for a different type of switch. If it’s not a dimmer switch, can you post a photo of the switch and fixture?
