Results 1 to 5 of 5
Thread: A Glimpse at an Air Spring
    Default A Glimpse at an Air Spring
    Just a short video on our coach's air springs. (CLICK HERE)
    Mar 2018
    Tres Pinos
    13
    Informative presentation Gil, thank you! Interesting how the inside of that air spring still looked new, at least from the video it did. Probably the result of a well maintained air dryer??
    525
    Gil:
    Thanks for posting the video, awsome to see the inside. I am having my 20 yr old front airbags replaced next week at Prevost in Winter Garden, There has been discussion of Prevost putting the wrong part # (airbag) on coaches and when you try to use level low the bus will not go higher then normal ride hight. Do you have any info on what would be the proper part # (airbag)? I have tried to research it and it gets a bit confusing with all the different types of bags avaiable.
    Chuck & Katrina
    2000 Featherlite
    H3-45 Double slide
    There is 1 choice for a correct applicable air bag for IFS UNLESS u have a real new bus 2018 or newer.
    Most prevo motorhomes r pampered inside. Some r not. I just was under a bus in west palm beach it sits under an awning but outside. As I inspect I noticed an extreme amount of surface rust on the rotors so I asked him when was his last trip. 3 months. I suggested he never let it sit longer than that in the future.
    If that can accumulate like that in 3 mo his stuff after 10yr will be not real good.
    Point being, I have pulled 10yr old bags off that looked almost brand new and I have removed others because at the same age the base was rusted through and it was leaking.
    Letting the rear down on the bags doesn't hurt 1 darn thing. Absolutely nothing. Same thing with a straight axle steer. If u r long term camping with a straight axle bus DUMP IT in the front, it damages nothing.
    Nov 2018
    PIEDMONT
    463
    Thanks for clarification Joe - I happen to know of one that is stored lowered.
    Billy & Lisa Gaines
    1996 Marathon XL40
