Results 1 to 7 of 7
Thread: 365 tire temporary replacement
    524
    Default 365 tire temporary replacement
    I have 365 on steer & tag axles. If I where to have a steer tire fail during a trip and a 365 was not available for a extended period of time, could the tag 365 get moved to the steer and a 315 put on the 365 tag rim to get you down the road to a safe location to wait for a 365?
    Chuck & Katrina
    2000 Featherlite
    H3-45 Double slide
    Chuck,
    Prevost installed 365s on the tag solely to support a front tire flat. This was when 365s were very hard to get. Michelin claims they are finally past that...we'll see. No, you can not mount a 315 on the wheel for a 365. Michelin confirmed this. So, you'll need a wheel and tire for the tag, if you can't find a 365.
    524
    Thank you for your wisdom Gil
    Another question. If a 365 was not available for an extended period of time and I was forced to use a 315 (on the tag) to move along, what size rim & hub would be needed on a temporary 315 wheel & tire combo to fit the tag which was accomidating a 356.
    Sorry if my question is a little confussing, I am a little confussed.
    Chuck & Katrina
    2000 Featherlite
    H3-45 Double slide
    Hey Chuck Joe here.
    U need a aluminum, Alcoa, 9in, 22.5, hub piloted rim for a 315-80 on the tag.
    Gill and Derlene could be occupied preping for that huricane thats yodling up the canyon.
    Chuck,
    As usual, Joe is correct. I really think you can use a steel wheel. The stud will be longer than necessary, but that should be okay.
    Joe correct me on the steel wheel thought.
    An exposed steel wheel on a prevo motorhome??
    For shame. OMG Unthinkable. LOL Only for those with no style.
    Joe,
    It's temporary. Okay, I guess a steel wheeled coach can forget about staying at the 10 year rule campgrounds and will have to seek out truck stops.
