Useful Toolbox Items
What's the unique tools you carry? The list could be used for holiday shopping ;-)
Inexpensive tool for making clean straight cuts in plastic brake hose.
This slips over the valve stem extension many use on the inner dual wheels. There's no easier way to tighten or remove the valve stem extension.
A ratcheting compact 90 degree tool for those hard to get to fasteners.
For those with manually adjusted fan belts, this is a belt tension tool.
A True RMS Voltmeter that also measures Frequency. The Fluke 115 is a good choice.
A clamp-on amp meter that measure both AC and DC current. The Fluke 325 is a good choice, although there are many much cheaper.
