Results 1 to 10 of 13
Thread: Marker light (XL bay door) LED replacement
    Default Marker light (XL bay door) LED replacement
    I am needing a replacement LED bulb for my bay door marker lights. I donít have a number to trace back to. Anybody have any ideas. I am going to try and post pictures to help th cause.
    Tony and Jenny Conder
    Abilene, Texas
    1997 Liberty Elegant Lady XLV
    2017 RAM 1500 4x4
    Abilene, Texas
    2017 RAM 1500 4x4
    Default Fixture
    Abilene, Texas
    2017 RAM 1500 4x4
    2,941
    http://www.bulbtown.com/mobile/Produ...ductCode=211-2
    Other sources may have LED versions. A few years ago the LED versions were too dim for me. I adapted square LED panels.
    Those bulbs are generally called "loop festoon" style bulbs. The two clips that hold them in place are spring loaded outward to hold the bulb in place. Led versions in different Kelvin colors are available from many sources. Measure the distance between the end loops to determine the correct size.
    Jerry Work
    Kerby, Oregon
    1997 Prevost Country Coach
    40 foot, no slides, Santa Fe
    decorating style
    2,324
    Do an exploritory if u r replacing the entire fixture remove 1 from the bus first to see what u r looking at. Sometimes the nuts that r crimped into the stainless that they r fastened with loose their crimp and spin. Sometimes the wire tail is not long enough at all.
    Great upgrade, and, don't throw away the old ones.
    708 243 7871
    Feb 2010
    Kansas City, MO
    493
    I have the LED replacement for your bulb. Festoon bulbs are offered in different lengths and there lies the problem. I think the bulb stuff is on my bus, like the part number from the vender.
    I'll be back tp you
    AL
    Checked vendor finding my account has been saved along with lasts purchase. Go to their web site below, address is hot.
    Purchased 23 of number ...6451 in "cool white". You might try customer help all depends on who you get or order one or two bulbs for a test in your housing.
    www.superbrightleds.com
    Al
    2010 GMC Arcadia AWD
    3rd Marathon, 1-XL 2-H's
    Gracias to the think tank. I will let you know what I wound up with.
    Abilene, Texas
    2017 RAM 1500 4x4
    I had the cool white ones and did not like them. I replaced them with warm white and like them much better now.
    Jerry Work
    Kerby, Oregon
    decorating style
    2,941
    If you want to replace the entire fixture, there are a few options, none of which use the same mounting holes.
    I like the Maxxima MWL-33. It's a flat mounted light with downward directed LEDs and cost about $35.
    Here's the light output comparison. Yes, the one MWL-33 shown does throw more light straight out even though most light is directed downward.
    Here's a great choice for your entry light next to the door. I think it's a bit pricey, but it's a Whelen product. They are all pricey. I installed one of these at my door.
    (CLICK HERE for Whelen Light)
