Jerry, its messing with you.
Jerry,
For night driving, put a band aid over it and say "OUCH"
Lew
No expert here.
But I've had the same problem on the '97. I would have to assume though the light is indicating there's a problem rather than it's just doing it's job.
Mike
From the take it for what it's worth..If I have the correct yellow light.
On my Marathon I had to replace the chassis Batteries as I was told the light indicated an equalization issue as one of the batteries was weak.
I learned the hard way if the person who helps you do this forgets to install one of the final ground wires to one of the batteries the light really goes off and on..Long story, anyways...
After replacement of the chassis batteries I have had no issue. The Prevost Manual states to turn off the 24V power when the bus is sitting to avoid the equalization issue. I now do this regularly.
So I hope after all the writing, I have the right light! Good Luck.
Why does this really cool spell check not recognize "Prevost"?? How did we miss that one?
I think Troy got it right. There was indeed a weak battery and I couldn't leave the coach for a week (even with both disconnects off) without them running down.
As of this afternoon, I have 4 new Interstate group 31 batteries installed and the light shines no more. I was impressed with how Prevost handled the battery "box" in that the rubber / plastic tray that they were in was easily cleanable and the hold downs were pretty slick to take off and reinstall. Whole job took about an hour including cleaning the cables and taking a digital photo just in case I fouled up the wiring.
JDUB - you got any rust on those battery drawers?
rust bullet is your firend. rustbullet.com . a little liquid detergent, some rinse water, a coat of rust bullet, all done. no sanding, no chipping, no nothing other than paint it on. problem gone.
