Results 1 to 10 of 11
Thread: Vanner Battery Equalizer
    Nichols Hills
    2,465
    Default Vanner Battery Equalizer
    Okay, I generally understand that this unit allows you to pull 12v power from a 24v system while not creating a charging / discharge imbalance in the system.
    And I have gone to the Vanner website and read thru their operating manual. However, I didn't glean from the file why the yellow light on the dash intermittantly comes on and goes out. I niavely thought it came on when the unit was "working" or correcting the imbalance since mine would come on sometimes when the coach was first started, but would eventually go out. And then sometimes it would come on for a while, but it would always go back off.
    Any wizard out there that knows whats happening with this thing? I can say the yellow light on the dash is quite annoying at night......
    Cool Purely Personal--------------------rating: 0/10
    Jerry, From your information. The light serves no useful purpose other than periodically indicating that the Vanner is in fact doing something. It however does not quantify or indicate any value or rate etc. If you did not see the light the unit would function just the same, kind of like colored strobe lights synchronized to the music, you don't need them to enjoy. I think this calls for the BLACK electrical tape! JIM
    Jerry, its messing with you.
    lewpopp Guest
    Jerry,
    For night driving, put a band aid over it and say "OUCH"
    Lew
    Alexandria
    2,161
    No expert here.
    But I've had the same problem on the '97. I would have to assume though the light is indicating there's a problem rather than it's just doing it's job.
    Mike
    Troy Stone Guest
    From the take it for what it's worth..If I have the correct yellow light.
    On my Marathon I had to replace the chassis Batteries as I was told the light indicated an equalization issue as one of the batteries was weak.
    I learned the hard way if the person who helps you do this forgets to install one of the final ground wires to one of the batteries the light really goes off and on..Long story, anyways...
    After replacement of the chassis batteries I have had no issue. The Prevost Manual states to turn off the 24V power when the bus is sitting to avoid the equalization issue. I now do this regularly.
    So I hope after all the writing, I have the right light! Good Luck.
    Why does this really cool spell check not recognize "Prevost"?? How did we miss that one?
  1. Replacing Two Vanner Equilizers
    By lloyd&pamela in forum Sparky's Corner
    Last Post: 08-31-2009, 05:15 PM
  2. Vanner battery cont. change out
    By Danss in forum Sparky's Corner
    Last Post: 11-05-2008, 10:43 AM
  3. AGM or Gel Battery
    By blacklab in forum WHERE TO FIND STUFF: Links and Resources
    Last Post: 11-05-2007, 07:07 AM
  4. MK 8D Battery
    By mikedee in forum Busted Knuckles and Greasy Jeans
    Last Post: 05-17-2007, 04:57 PM
  5. Battery Equalizer
    Last Post: 01-03-2007, 11:05 AM
