Results 1 to 3 of 3
Thread: Lurkers...
Hybrid View
    Just Plain Jeff Guest
    Smile Lurkers...
    Here's the place to make your first posting on the POG board.
    It's always a good idea to ask a question that most people won't be able to answer since it then gives you the opportunity to find out that you probably already knew more than you did.
    I think that makes sense.
    Nov 2006
    178
    Default Newbie can't follow directions
    So Jeff,
    If I understand you correctly, I didn't properly introduce myself by placing my first post under transmissions, etc. instead of the new member category, but I did good with the part about asking a question no one can answer? Is that right.
    Richard Beecher
    '96 Vogue XL 40
    You dun reel gud.
    Now you can tie into something like...What to do when you run out of fuel...?
    There's an easy answer to the question which will be revealed at POG III, after the Secret Handshake Ceremony. And you thought you could just buy your way in here.
    Hah!
