If u want to boon dock and be off grid in a liberty in the summer solar reguvination of the batteries would be very bennificial in keeping the water in the fresh water tank cool. If hot out and running gen for a prolonged period with a liberty will make it diffkcult to keep any cold water with a generator in the plumbing bay. Vogue same issue.
Once u get north of mid 90s after 2 or 3 days if u r not going thru water and replentishing it it will get pretty hot and imho hot enough to be a nuisance.
I have showered in a liberty with the valve totally on cold and the water totally hot a few years back during an extended trip thru Tx. In the heat of summer.
Imo the general responce from most prevo guys on solar is normally not very receptive. ive seen solar fabrjc they make blinds out of it. Someome should do the topside of awnings with it. Good luck with your search.
