The Magpul bus gives a whole new meaning to "gun it". Sorry that was a cheap shot.
Hi Jerry,
Based on my experience with two restored GMC motor homes it will be quite a challenge to pull one behind your Prevost unless you put it on a full flat bed trailer. If you do, watch your overall length since the GMC is likey 26’ long. The front wheels cannot turn while towing (the FWD auto transmission won’t be properly lubricated) and just lifting the front results in being low at the rear even with the air bags inflated all the way. And, the only good place to grab one is via the front cross member which is set far enough back that you can damage the front bumper, radiator or front fascia if not really careful. A properly equipped tow truck can manage a tow with the front off the ground if they go slowly (which most won’t).
