Results 11 to 20 of 26
Thread: TMPS
  1. #11
    Nov 2006
    Huntsville
    3,135
    Jim/Roger, Are you still using the Tire Safeguard System? I think the batteries were supposed to be good for approximately 5 years. I may need to buy my old system back from Gil!
    Dale & Paulette
  2. #12
    Mar 2013
    Chicago
    3,988
    Test test this
  3. #13
    May 2012
    Beverly Hills
    4,652
    Dale, I never used it. Make me great offer.
    Gil and Durlene
    2003 H-3 Hoffman Conversion
  4. #14
    Jan 2007
    1,600
    Yes I am still using Tire Safeguard and some of my batteries need to be replaced. The good part is they can be replaced. The bad part is when they are replaced the control unit needs to be re programed. I don't find this procedure to be user friendly. I will probably opt for sending all of them into Tire Safeguard and have them do it for me. Over the years I have had both the standard tire sensor and the flow through sensor. I prefer the flow through sensor because they allow you to manually check the tire pressure to confirm the pressure being reported to the control unit. It is also nice to be able to add air without removing the sensor.
    99 Country Coach 45XL
    Jeep Liberty
  5. #15
    Sep 2014
    The Villages
    41
    I also use the Tire Safe Guard. I replaced the Pressure Pro system with the Tire Safe Guard. I like the Tire Safe Guard better. It seems to be more consistant and reliable. Plus, you can change the batteries yourself.
    Mikee
  6. #16
    Feb 2006
    Bristol, Tn
    1,647
    Yes Dale, I am still using the Tire Safe Guard - actually 2nd set. I tried the Pro Sensor but it was left on one of the previous buses. The Tire Safe Guard is my preference.
    I also agree with Jim that it not that user friendly when changing sensors but somehow I got it to work when I had to replace a lost sensor.
    Roger that!
    2008 Liberty DS XL2
    2023 Denali Ultimate
    My 6th Prevost
  7. #17
    Sep 2014
    The Villages
    41
    That is what the sensors do when the battery is getting low. Replace the battery.
    Mikee
  8. #18
    Nov 2006
    Huntsville
    3,135
    Gil, Can the batteries be changed in the sensors you have?
    Dale & Paulette
  9. #19
    Sep 2014
    The Villages
    41
    I have changed the batteries in the TIre Safegard and did not have to reprogram anything. have to do after changing the batteries?
    Mikee
  10. #20
    Nov 2006
    Huntsville
    3,135
    Gil,
    Can the batteries be changed on your sensors? I am interested.
    Dale & Paulette
