Results 1 to 9 of 9
Thread: 75 amp red dash light
    Feb 2014
    Chiefland
    20
    Default 75 amp red dash light
    I have a 1999 Marathon. The red 75 amp caution light came on and stays on when engine running. Volts are good, 28V with engine running. What do I do to fix this problem
    Thanks
    Nov 2006
    Huntsville
    3,135
    Larry, Where is this light located? Obviously, I don't have a Marathon, and I don't remember this light on the last Marathon I had.
    Dale & Paulette
    Feb 2014
    Chiefland
    20
    The light is located with a group of caution lights on the left side of the dash by the drivers window.
    Nov 2006
    Huntsville
    3,135
    Larry,
    From what little I know about this, there should be an icon that shows in the light. It may be showing an engine, or one side of the coach, etc. What does yours show? Normally, if it is a solid red light with no icon, the light is located on the front of the dash instead of by the driver's window, so I'm assuming yours has an icon in the light indicating where the problem is located.
    Dale & Paulette
    Feb 2014
    Chiefland
    20
    Got if fixed. Ends up if you cycle the jump start switch it will reset the 75 amp caution light. The red light said 75 amp on it.
    Thanks for your assistance.
    Mar 2013
    Chicago
    3,988
    Does anyone with a 90s marathon with Howard Active steering want to help with the controls.
    Marathon did not use the standard Howard Controls they used their own. It has an illuminated square dash switch for on and off. Below that is a small black round knob with 4 selections unmarked and another small black round knob below that Im pretty sure that feels like air regulator pressure adjustment and they also put the pressure gauge for it right in the dash.
    Figured out the on off and the regulator knob but what is the knob between them with 4 choices??
    The operators manual shows the standard Howard controls couldn't find any other info in the books yet.
    Ran into another bus I fell in love with today a Beautiful Marathon. And its an XL(40).....nothing better
    Sep 2008
    836
    Joe, my coach has the Howard steering....I would like to find a hydrolic cylinder for it, or some one who can rebuild mine. It is an great system, but hard to find someone who can rebuild it. If you know of one, please let men know.
    Pete & EJ Petree
    Sealy, Texas
    Apr 2010
    Clearwater
    231
    The Red "75-amp" light is the alternator telltail light that the "relay output" on the alternator has no voltage. On a Marathon, the 75 is for the chassis alternator charging the Prevost start batteries, and the 270 is for charging the Marathon house batteries. These lights can occasionally come on if the batteries are fully charged and the alternator voltage regulator has effectively shut the alternator down.
    Ben Cummings
    U.S.A. Luxury Coaches, LLC
    Clearwater, FL
    Feb 2014
    Chiefland
    20
    Very interesting! Thanks
