Dale,
Roger and I just replaced all the air bags on both our coaches. I ordered mine through Prevost in Elgin. I spoke to Charlie Kailor who is very helpful.
I also shopped airbags from other sources and hands down Prevost is the source of choice on airbags. They stock them, the price is right, and you will get the correct one if you are specific as to what coach you have. Make sure your Prevost serial number is available when you talk to Prevost.
I replaced the air bags on my 40 footer years back, and I don't think there are any "gotchas" except if I recall the rear drive axle bag removal can only be done if you remove the shock absorber. Not a big deal, but necessary if my memory is correct. Air bag removal on a 45 footer is easier. The fronts should be modified to make removal easier and future replacement a snap.
I have a single observation about air bags based on what appears to be anecdotal evidence. They likely have a life span of about ten years. On my first coach that was when the first failure occurred. It has happened on Mike's and Roger's coaches also. Both are in the 10 year age range. Because of that, as preventive maintenance I would strongly recommend that any airbag that is 10 years old should get replaced.
An on road failure of an air bag is a show stopper. You might be able to drive to the shoulder, but you won't get much further if the air bag fails catastrophically, and if the air bag failure is a leak and not a blowout, that leak will only get bigger, and at some point your compressor will not be able to overcome the air loss.
