Results 1 to 7 of 7
Thread: Water Softeners !!!
    Sep 2011
    Altoona
    451
    Default Water Softeners !!!
    Hey everyone sorry I haven't been on for awhile, worked on selling our lake home all summer and sealed the deal right before we we headed south for the Islander resort in lake Havasu City AZ,
    So we are officially Full Timers !!!! Yeaaaa
    Anyway I was wanting some input water softeners they rent the tall metal ones here $35 a month or so, but I was wondering about buying my own, my neighbor down here last year had one it was a blue bottle looking thing that ran off Morton table salt well he ditched it this year and is renting he said it used way more salt and was a pain the the butt?? I have seen guys fighting other ones square and light brown hoses coming off everywhere and the seem to spend allot of time with them, Is there a real good one out there for traveling even if we spend a little more money on the investment
    Any opinions greatly appreciated !!!
    Larry & Nancy
    Midwest
    2000 45ft Prevost Featherlight Vantare XL 17ft slide, an Overbuilt Motorcycle lift and sterling tow bar to take lots of fun with us
    2012 Black Jeep Rubicon OEM Lift Bilstein shocks, PowerPlant Duel Force Warn 9,500 lb Air/Winch
    1998 FLSTS Custom harley
    One Chocalate Lab " Rooster " Our Baby !!!
    Apr 2006
    Battle Ground, WA
    851
    If you have the bay space the Kinetico model 50 works very well. It can be adjusted so the water isn't slippery soft.
    Jul 2013
    Steamboat Springs
    2
    I have been using a Flow-Pur RV-Pro 10,000 for the past year and am quite happy with it. Uses table salt and is relatively easy to regenerate in about 30 minutes. I am single and with my normal water usage I regenerate about every 21 days which is about what they advertise. I paid $275 for the unit on line. Only issue I has was the plastic green Y fitting on the outlet side broke from all the in and out of the storage bay when moving around a lot. Picked up a stronger brass Y and glued the regeneration outlet restrictor into the new Y, no issues since. I permently mounted a sediment filter on the inlet side of the softener as the water at many campgrounds / RV resorts is well water and has lots of minerals. I replace the filter carterage every time I regenerate which really extends the life of the filters in the coach.
    Nov 2006
    Wilsonville, OR 97070
    852
    Mld are you saying you replace salt and filters every 21 day. That could be expensive.
    Jul 2013
    Steamboat Springs
    2
    Two containers of table salt @ $0.49 each. 5 micron filter cartridge purchased in bulk on line at under $5.00 each so total cost to regenerate is $1.00 every 21 days or $6.00 if you want to change the filter that often. The pre-filter extends the life of the expensive filter canister and the cartridge filter in the coach. Only change these filters once a year with the pre-filter prior to the water softener.
    Nov 2006
    852
    What pre filter are you using?
    Sep 2011
    Altoona
    451
    Very interesting set up ? good info, I will check that option out, My neighbor and his wife ended up having to regenerate way more than advertised, Probably depends on dishwashers or laundry I don't use either the wife just takes the clothes up to the laundromat and does them all at once, That way after they dry she don't have to untie them .)
    Larry & Nancy
    Midwest
