Results 1 to 10 of 30
Thread: Webasto Operating Question - CC XL
    May 2013
    Cincinnati
    59
    Default Webasto Operating Question - CC XL
    11/4
    Hi to Country Coach XL owners. I found very little in the publications with my coach about the Webasto. Getting into the 20's a week ago was a wake-up call. The new DuoTherms worked well on the heat pump cycle and brought it up from the 40's to 70 in no time. I have the Webasto system. Checked threads I could find. Seems as though some work from the thermostat; others have on or two separate just for the Webasto. I do not see separate controls. I do have Webasto/Heat button/switches overhead in the cockpit. Do I just fire up and off as needed? I do not see any temp adjust panels...... Thank you if you can help.
    Sincerely,
    Doug
    Nash XL
    1999 Country Coach
    Huntsville
    3,135
    Doug,
    I don't remember the settings, but there are very specific guidelines for getting the system working properly. Jim K. or Gil can give you those instructions.
    Feb 2012
    Bradenton
    317
    Doug, after you start it with the button you mention, you set your thermostat to furnace mode in zones 1&3 and set the temp.You also have to turn the heat exchande buttons on up front, in the galley and in the bedroom.
    Corey Grubb & George Prentice
    1999 H3-45 Vantare
    Will & Grace-fierce felines
    Cedar Hammock, FL.
    The road goes on forever
    and the party never ends
    May 2013
    Cincinnati
    59
    Hi Corey. Holy Crap Batman! Makes me yearn for the days of our low brow Class A with gas heat. Separate thermostat, set it for the coach and basement.
    Does the system work well if operating properly?
    Follow-up question. They installed the new digital Dometic thermostat with the new A/C/Heat Pumps. My zones for the three are 2,3 & 4. One doe not have a function. guess I should call Excaliber about this for the Webasto settings.
    Did you guys get the coach to the shop for the cosmetic touch-up (being positive). Too nice looking to leave roughed up. I thought you said it was going in after Branson.
    Sincerely,
    Doug NashXL
    Feb 2012
    Bradenton
    317
    Doug, whatever zones have a furnace mode. Our thermostat has it on 2 zones. Basement automatic. Make sure all your heat exchangers are on. Coach has been at Walter de Andrea since Oct. 24. You comming to Fla. at all this winter ?
    1999 H3-45 Vantare
    Cedar Hammock, FL.
    May 2013
    Cincinnati
    59
    Corey -
    I checked with Doug. Since my new therm is on 2,3 & 4 the Webasto is on 2 & 4. I'm gonna give it a try. Thanks for the help. Will be in and out of Tampa for my company. Not sure about bringing the XL through KY and TN and the fog and icy mountains in winter. May have to buck up and fly more. May head to Austin next week for the Formula 1 and support races. Still have a few 57' x 20' MH spots left. $998. for five days and you get 4 - $169 all weekend general passes. It is supposed to be a party blast. 1,156 miles according to google so I need to decide. I know it will be warmer down there!
    Doug
    Doug,
    -- Set your thermostats for Furnace and adjust the temperature. Only your first and last zone has a furnace mode (you knew that). Why yours are numbered 2-4 makes no sense.
    -- Turn on Interior Heat Control above driver's seat. You may have to wait for the thermostat to activate the furnace function.
    -- Adjust the heat exchanger fan speeds (dash, galley, and bedroom). These are panel controlled.
    As already stated, the basement heat is automatic after turning on the Central Heat control. Here's one you may not know (I didn't). When the central heat control is on, it will heat the hot water if you turn on the hot water heaters. Shore or generator power not necessary.
