I just moved my bus after it was idle for 2 weeks. It was not plugged in, but everything was turned off that I could turn off. There was no power available where I had it parked. I have now plugged it in to a 50 Amp service, but my house batteries say "Low", and the beeper by my batteries is beeping continually to warn me of low voltage.
My dash panel shows that the two 2500 watt inverters are charging and shows voltage to be 26-27 volts. I don't know how old the batteries are, but this is the first problem I have noticed. I just turned off the 12V and 24V disconnect switches in my battery bay hoping this will help the batteries charge again.
I am wondering if this low voltage is a sign of one or more bad house batteries? The bus has been plugged in for over 24 hours now. Need some advice. Thanks. Dale
