Results 1 to 10 of 10
Thread: Air Brake Test
    May 2012
    Beverly Hills
    4,652
    Default Air Brake Test
    Although I realize we aren't subject to the regulations that commercial vehicles are I sutumbled on this CDL brake system test and thought it might be of interest to some.
    http://www.thetruckersreport.com/cdl...ts/air-brakes/
    Gil and Durlene
    2003 H-3 Hoffman Conversion
    Mar 2013
    Chicago
    3,988
    Well............I really thought I could ace it. No good got 4 wrong took 11 min.
    Nov 2006
    Huntsville
    3,135
    I thought the same thing but never heard of some of those questions. I think Gil is trying to make us look bad. He probably aced it!
    Dale & Paulette
    May 2012
    Beverly Hills
    4,652
    I missed 2 and guessed at 2
    Gil and Durlene
    Nov 2006
    Huntsville
    3,135
    I did it in 5 minutes,. Guessed at 5 and missed 5. Bad guesser, or just plain dumb!??
    Dale & Paulette
    Oct 2012
    Washington
    45
    Got only 4 correct in five minutes. So much for common sense guessing. From other scores posted here, could there be something missing with the POG gene pool?
    Nov 2006
    Huntsville
    3,135
    David,
    Maybe its just that we're honest.
    Dale & Paulette
    Sep 2008
    836
    80% on both tests.....close, but passing.
    Pete & EJ Petree
    Sealy, Texas
    Mar 2013
    Chicago
    3,988
    AND if U go back and retest U will get slightly different questions in slightly different order. That's got DMV written all over it. If U want to really help folks by teaching them correct info with a test then loose the vague questions with all bad or equal choices. I was surprised about the 3 psi loss per minute question. That's not the standard I was familure with. Can U imagine heading down the continental divide with a bus that's loosing 3 psi per min? Even if U did not even touch the brakes your compressor would run every 6 minutes. Isint that crazy?? Next time U R doing a tango with a big truck this is the safety standers they R held to. And the question about the single air system IMO is useless info did U guess I got that one wrong. If I were the teacher I would not want the pupils going away after the test more confused than before they took it.. Sheeeesh. Good grief Charley brown. I think we should do a BUS RODEO at a rally big money to enter real tough course. We could do it all for charity.............and bragging rights I gotta get another bus
    Mar 2009
    Harrison
    623
    Hard to believe you've been this long without a bus...any bus....Joe
