Prevost Now Offers :
Remanufactured Meritor Calipers
[/COLOR]
[/COLOR]
2005 Marathon H3-45 # 0867
2013 Chevy Avalanche
Be sure you have the corrisponding 2 dollar rubber dampners for each caliper without them it may bang around and do unnessessary wear on the slide pin bushings . They fall out or possibly less than adiquate shops do not see their importance or I could see how some shops may make this mistake just doesnt get put back.
If you put them in right they are pretty much "in there" so I wonder about hubs where the piece is gone and Ive seen my share.
2 bucks pretty important
If you have these calipers on front and tag axles next time the rims are off be sure the calipers on all these hubs all have these little rascles.
Wow, I wish they had rebuilt Knorr Calipers....I just had to replace one on one drive axle and all they had was "new" and they ain't cheap (but it was a "real joy" to replace it)!!
MB
Marathon XLII
The calipers you have on the drives on your XLII are not the calipers pictured and noted in this thread.
Your brakes are knor-bremmer or something close to that spelling.
On those brake calipers the weak link to watch for is the dust boot for the lower slide pin. Often it cracks and when it does those slide pins are doomed.
Every time you have the bus serviced you should block to wheels release the brakes and have the guy lubing grab each of the calpiers from below and see if they can be jiggled. If not the lower slides are probably beginning to stick. The Upper slide pins are completly different they are exposed to the eliments and they generally do not create issues.
If any of your calipers can not be jiggled from underneeth with brakes released or if you can visually see the dust boot cracked or damaged on the lower slide pins get the slide pin kits soon. Thet are like 45bucks.
Good idea to have a kit in your spares Ive seen many cracked lower dust boots.
Another thing about the knorr caliper rebuild kits there are 2 different lube packets in the kit. 1 is specificly for the top the other for the bottom.
I grease is green 1 is white I always forget and waste time verifying here is the ticket.
If you look at the volume indicated on the packets you will find that 1 is slightly more than the other the bigger amount goes on the bigger slide the bottom one. Hope that helps.
Joe, are you talking about the rubber boots on the two pistons? On the new caliper I just installed, the lower pin had a metal cup to seal it rather than rubber.
I just replaced the caliper and the 2 supplied grease packets for the pins/bushings were the same.
Maybe I don't understand which rubber boots you're referring to????
Marathon XLII
You are an XLV i looked depending on your year your calipers are or could be a 3rd flavor.
Do the photos in the original post in the thread resemble your calipers or do they look obviously different.
No, mine are Knorr and are completly different on my '01 XLVII
from the Meritor.
Thanks..
Marathon XLII
The 01XLII is the chassis with the 2 different slide pins and the questionable lower dust boots
Here are the small 2 dollar rubber dampners that need to be between the calipers and their mounting bracket.
