Results 11 to 20 of 47
Thread: FMCA - Michelin Advantage tire purchase program. An Update
    1,138
    We like michelins, but the next set of tires we may rethink purchasing since most tires we all buy will age out. Factoring cost per mile per year, michelins are expensive. When we bought the current bus, we had our choice of any tire. Fiirestone FS400's, 315/80/22.5 were the next choice after Michelin, reason being the FS400's ride smoother. Past several busses had Michelin Pilotes,not made any longer, which when new we could definitely tell they were new by how the coach rode......smoothly. The Michelin Energy tires known for less rolling resistance hence gaining you a bit better mpg are made of harder compounds, resulting in a slightly harsher ride. Owning an 8V equipped coach, the mileage increase gained by running Michelin Energy tires might be a couple of percent over 10,000 miles. We have recently had comparable mpg increases just by towing a lighter towed car, and slowing down. Remember, every five miles an hour over 55 mph, adds thirty cents to every gallon of fuel burned. Running from home to OKC to Las Vegas to home towing a 3400 lbs car instead of a 5700 lbs car, we gained .2 mpg over the 2500 mile loop we have before. (I-70, I-35,I-40, I-15, I-70)
    Oct 2012
    Washington
    45
    Jamie - here's an interesting POG thread on the subject of tire brands. Toyo, Hancook, Double Coin, are several little-known ones that manufacture 315/R80 22.5s.
    There's gotta be a reason why the original equipment on the shells that came out of Sainte-Claire, Quebec over the decades were Michelins.
    In my mind the price at the FMCA deal and the known quality of Michelin tires make it an easy decision to purchase the Michelins compared to any other brand for my bus.
    Aug 2012
    Eagle River
    21
    We bought 6 tires from Pomps Tires in Iron Mountain Michigan. Pomps is an upper mid-west tire dealer. Bought tires through FMCA pricing with no problems with Michelin or the tire dealer. We were even paid $100 each for our 6-1/2 year old tires with side-wall cracking. At this kind of pricing, why would anybody pass up Michelin tires? If you go through the proper steps/phone calls, for verification, you'll have no problem. It's a no-brainer. Iron Moutain Pomps - cudos to you!!!.
    Apr 2012
    Cameron
    55
    On the subject of tires...we just returned from a trip to the Keys. While on the Florida turnpike the passenger tag tire blew. I used Sam's club and had great service. We had a spare so drove home to North Carolina on the spare. I have two questions and one comment for all you wisdom figures.
    1. Any suggestions on a replacement spare?
    2. About ten minutes before the tire blew another driver signaled to me(as best as I could understand) that I had a flat tire. I stopped, checked the tires and could not find anything wrong with any of the tires. Can anyone tell me what I missed when I checked the tire? Maybe the tread was separating and I could not see it when I stopped?
    Fortunately, the blown tire was on the tag wheel. I called Prevost since I was 7 miles from the nearest exit. They assured me I could drive to the exit with the tag wheel up so that the service man could change the tire in a much safer location.
    Thanks, Otto
    Huntsville
    3,135
    Otto,
    I think you are probably right about the tread separating and being in a place you couldn't see when you stopped. I don't know of anything else the driver could have seen. Fortunately, you spotted it before more damage was done. I had an inside driver tire blow and take an airbag with it.
    If that was a 365 I have 2 that you can have for free,they are 2005 dates.
    It's possible the motorist saw the tire wiggling due to extremely low pressure. When inspecting your tires it's a must to check pressure.
    Most conversions, especially XLs, ride extremely low in the rear when the tag is lifted. For that reason I almost never raise tge tag. If driving with the tag raised make sure the rear axle tires are inflated to safely carry the extra weight. FWIW, your rear axle likely exceeds its maximum weight rating and the Feds maximum axle rating. If you must drive tag up, slow down.
    Oct 2008
    Tavares
    1,088
    I went to TCI in Orlando today - per recommendations from this thread. Very Good experience !! The Michelin prices were the same as quoted earlier in the thread - $ 586 + fet + installation. A local tire store is supposed to give me $ 75 per tire for what came off the bus. I guess I am good to go for a while...............
    I would recommend TCI to those who are in the Orlando area and need tire service.
    Jamie
    2005 Marathon H3-45 # 0867
    2013 Chevy Avalanche
    Sep 2012
    Grafton
    182
    Are these the kind of tires that would be used on a semi-tractor and/or trailer or a dump truck? Disregarding time, how many miles will these tires run? Has anyone had any luck selling to a trucker or a dump truck guy (someone who puts lots of miles on a truck) after four or five years for a decent price?
