Results 1 to 6 of 6
Thread: Nicro fan
    Aug 2008
    Walla Walla, WA.
    504
    Default Nicro fan
    There is a fan with stainless ring approx. 10-12" mounted on the roof above the toilet, and a 4.5" hole in the ceiling that the fan draws through. I think the mfg. is Nicro. the fan is controlled, on/off only, by a Sun Moulen switch in the toilet area.
    Can anyone point me to a source for this fan--their web site is not real helpful.
    Thanks
    May 2012
    Beverly Hills
    4,652
    Larry,
    If it's a Nicro it's likely this model or the 500 with an add-on stainless cover, http://www.marinco.com/product/3-white-minivent-1000 Both of these are only 7" in diameter. These and similar are available at Amazon.
    Our coaches are likely the same. If you'd like I can check mine tomorrow.
    Gil and Durlene
    2003 H-3 Hoffman Conversion
    Aug 2008
    Walla Walla, WA.
    504
    Yes Gil, plz check your fan, thank
    Oct 2011
    Moultonborough, NH, and St. Petersburg, FL, or on our sailboat somewhere else.
    116
    Since I replied to this post on the neighbors' board, I will copy my response here, for the benefit of POG.
    Quote
    Your solution may be found on eBay, see link!
    Hi Larry,
    Search for item * 120825504508* *These are the 12 volts model with rechargeable battery for nighttime operation. The cost is $83.00 including shipping. That is a very low price, considering the new cost was easily 3 times as much.
    Cheers,
    Ronald
    Unquote
    Aug 2008
    Walla Walla, WA.
    504
    Thanks Ronald, I'll check it out.
    Mar 2006
    Santa Barbara
    3,177
    Did you try Grainger ?
