Let me say up front, that I don't think there is a button I can push or something that simple to solve this problem. I've noticed that several times when I park the coach and level it, the right side drops down after a short while. The air pressure stays about 110-120 on the dash gauges for a couple days before they drop significantly.
It was really cold for Florida last night; went down to freezing about 10 p.m. and got to about 18 by early morning. When I went to move the bus at 12:30 today, I started it and let it fast idle for about 10 minutes. The temperature at that time was about 36.
The "Low Level" light went off as it should, and the air gauges were normal. I started down the road and noticed the right side of the bus was not running level. Pulled into a parking lot, shut off the bus, started the bus again, put the air control to the "Drive" position and waited for it to stabilize. It never did. I manually lowered the left side of the bus and tried to raise the right side, but it moved only a fraction of an inch. The best I could get was the right side off the ground about 8" while the left side was 12.5-13". Unfortunately, I don't know of a good place locally to check this out for me.
Is there a switch or valve that may be causing this?
Is that a chance I can get to it to replace it?
Is it more likely that I have an air bag leaking? Would my dash gauges still be reading 110-120 after several hours if I had a bag that was leaking?
If I have a sticking valve, could the cold weather make it worse?
Can I get Jon to bring his pit to Florida to help me trouble shoot and repair this?
I wish there was something goofy I was doing that might compare to the heater problem I really didn't have. I have an idea that this problem may have been manifesting itself in other ways, because the people I bought the coach from told me that they always lowered the bags all the way every time they parked. Of course, when you do this, you don't notice that the right side looses air. But this is the first time it has failed to go to the "Drive" position while running.
