Jack makes all good points. In an XL, 2000 and prior are rivet coaches, but that's a good thing as 2001-2005 XL's can have de-lamination issues. If you look at non-slide coaches, the onlly issue with Liberty's of that era is trying to find one with a cross bed and you lose the large rear closet in a 45. Marathon and CC rear and dash AC woks just fine unless yoy spend a lot of time in the desert, also properly ducted roof airs have certain advantages over cruise airs. they leave you with more storage space,much less expensive to repair or replace and give you a little more control flexibility. I would be a little hesitant about cruise airs in a 10-15 yr old bus. As usual Jon is right about see,feel,touch and smell-so you might want to think about going to Fla where in 2 or 3 days you can see a lot of various coaches in a small radius. Just go see Coachworks, Parliment, Florida Luxry Coach, Millenium and Liberty as all are pretty close to each other.
Corey Grubb & George Prentice
1999 H3-45 Vantare
Will & Grace-fierce felines
Cedar Hammock, FL.
The road goes on forever
and the party never ends
