Results 11 to 20 of 24
Thread: Generator Air Bag setting
  1. #11
    Jan 2007
    1,600
    Good One Jim !
    99 Country Coach 45XL
    Jeep Liberty
  2. #12
    River Ranch, Florida
    382
    Thanks guys, Its nice and dark in the area where my guage is mounted, so I'll not bother with a picture.....
  3. #13
    Sep 2009
    Houston
    240
    You did a good job of dulling.
    Pres
  4. #14
    Mar 2007
    Reno, Nevada
    237
    My Power Tech 20 KW is set at 30 PSI all four. 30 PSI is the Marathon spec on this coach.
  5. #15
    Pinehurst
    950
    The rear air bags are set at 29 psi and the fronts at 24 psi. I spent a fair amount of time with the pressures to get the quietest operation of the generator. Anything higher or lower results in significantly higher db inside and outside the coach.
  6. #16
    Jan 2007
    1,600
    Loc, I didn't realize you were so High Tech. I think I will try your numbers.
    Jeep Liberty
  7. #17
    382
    Thanks again, guys. I guess the next time I'm visiting Jim's famous "KKK", I'll have to attempt to set up a seperate maifold for the rear bags so I can have different settings. For now, I may just drop it on isolator blocks and see what the noise/vibration is like.
  8. #18
    Sep 2008
    836
    Loc only deals in MILLIONS! not pounds'
    Pete & EJ Petree
    Sealy, Texas
  9. #19
    Apr 2007
    Miami,fl
    309
    Where is regulator and pressure gauge located ?
    Granvil Tracy
    2000 Vantare XLV45, S-2
  10. #20
    Feb 2009
    Austin, TX
    963
    Quote Originally Posted by Pete View Post
    Make that Billions Pete....
