Gary I'll try your steps.
Charles the aux air compressor is only raising the pressure to 110 then goes off so do you still think it is a problem. One thing I haven't checked is to hear if it is making the noise when the compressor goes off.
I never found an answer to mine doing this. It sounds just like a fog horn as you say. I think it is air pressure trying to equalize between the canister that serve the drive axel brakes. It just stopped on its own I think or, maybe it stopped after I had all my air bags and Norgen's replaced. Not sure.
i had a similar problem on a bluebird and it was a check valve. just a thought.
