Results 1 to 4 of 4
Thread: CLS Failed Low
    Oct 2010
    190
    Default CLS Failed Low
    OK you experts our there!
    My neighbor experienced an alarm on his Detroit Pro panel that stated" CLS Failed Low". I can only guess that it means Coolant Sensor Failed Low, again guessing the computer has sensed the sensor is shorted or open? He stated he received the alarm and was still able to normally drive without any issues. He did check the coolant tank level in the rear and all looked good.
    I also guess, a new coolant sensor would be the first step in troubleshooting?
    I hate to guess among the giants in the Prevost world, it seems to always turn out not good.
    Any Ideas?
    Hector
    Dec 2010
    Penetang
    117
    I believe there are two coolant level sensors the first trips the code and the second puts the engine in protection mode. Below is a manual that should answer your questions courtesy of Prevost. Gotta love the internet!
    http://prevostparts.volvo.com/techni...pdf/7SA743.pdf
    Oct 2010
    190
    Thanks,
    Hector
    Jun 2009
    Gig Harbor, WA
    340
    Hector, to eliminate the tank sensor just unplug the wire from the sensor, take a small jumper wire and short across the contacts if the alarm stops you know it's that sensor.
