The oil sensor could be bad. It will shut down the engine.
Gary, Roadside asst. came out could not fix, friend is on with Prevost now. Question, can the oil sensor be overriden or wires removed to temporaryly not trip engine shut off till we can get to detroit repair shop. Thanks it could be that. Ray
Call Prevost and they will walk him thru it.https://www.prevostcar.com/?q=conten...service-system
Yes, the sensor can be disconnected but I do not have the particulars.
Gary and the many pog members that gave us some help on our problem. Yes, it was the oil sensor that was bad, happy to report Tampa Diesel in Tampa,Fl came to the Super Show and repaired the unit and also noticed that there was a warranty recall on the unit and asked to come to the shop when there work was completed and have it done. It took about 3 hours all no charge, I think they called it Barimetric Pressure Sensor and was under full warranty. Thanks again, hopefully after a couple of years I might be able to help someone owning a prevost. Ray and Charlotte
Its good to know where these 3 sensors are on your coach. Some folks carry spare sensors.
