Use of Guest Charger while Driving.
Up until now I have use a cord to plug in the Guest Charger when stopped. I recently installed an outlet in the engine bay so, no more dragging the cord around, then----[dangerous I know]---- I got to thinking, what will prevent an overcharge or some other problem due to two sources of charge to the chassis batteries if I leave the charger pulled in at all times ?
Thanks for the help!
My charger plug, I use for my Guest charger only is on when plugged into shore power or when generator is on. I think that is your question.
Also, the Guest goes into float mode when the batterries are fully charged.
Larry, My generator has a Guest Charger attached to the battery. When the generator starts the charger recognizes an incoming source of charge from the generators alternator and stops charging. Lights on the charger seem confused but the company said it has diode protection and will be OK.
Hope this helps.
99 Country Coach 45XL
Jeep Liberty
Larry, A few months ago when I finally got around to installing my Guest charger I had the same concern so I called Guest and they didn't really know if having two charging sources would damage the charger but they recommended unpluging the charger before starting the engine. I did however forget to unplug it once and there didn't seem to be any negative effects on the charger but it just makes sense to me to unplug it and not take a chance.
I know that the chargers should not hurt batteries but I have found that the guest charger on all the time will actually overcharge the starting batteries and reduce the life of them.
Here is the Guest 2611A, which I have installed. It has 3 stage, and maintenance so it will not over charge. I've had no problem keeping it permanantly wired.http://www.ebay.com/itm/Guest-2611A-...062#vi-content
Ive had it installed for about two years now.
Scroll down to see the specs on the link.
Suitable for wet, AGM, GEL 10 amp , 12/24 volt charger
Gary, that is the charger I have. My concern was the batteries receiving a charge from 2 different sources while driving or, more correctly, while the engine is running. From the responses here, there must not be a problem.
