Originally Posted by
Pete
Fred it is Prevost P/N 640938, Regulator, Belt Tension Air. available from Prevost for about $58.22 plus tax. Been there, done that!
If you have the feature that lifts the tag when you turn the steering wheel sharply in either direction. On my coach, it can be deactivated by a switch on the transmission console. (which I keep turned off). It is easily replaced, and I forget what the pressure should be set to, but the guys at Prevost can tell you. It is also used for other applications on the coach, but I would bet that is your issue. Hope this helps.
