Ibriant, Welcome to the group.,
I believe, and someone can correct me, Kevin??? one reason the hitch upgrade is costly, is it tied into the engine cradle. I think you need to replace th whole thing. Extreme weighted trailers can cause all sorts of trouble. More on a coach can be stressed than just the hitch attachment point. Other components such as drive and tag axle bearings will be stressed with added weight which causes more heat, possible premature failure.. Unless you use some sort of load-leveling weight distribution hitch to transfer some of the trailer's tongue weight to all three axles,( the bus suspension will compensate for bus leveling), it doesn't change the fact that weight will be removed from your steer axle, possibly jeopardizing total bus handling. I would ask this one question, do you really need such a stout trailer. We cringe when we see huge trailers attached to coaches, especially ones we know were originally designed for 10,000 lbs. Even the Overbuilt motorcycle carriers with a bike loaded, makes for enormous amounts of strain on the coach chassis as a whole. What are you planning on loading a trailer, not to be nosey, but curious.
Jim and Chris
Previous 22 years,
