I just joined the group and this is my first post. I'm about tear into a long punch list of the Royal we just purchased and since this is my first serious RV I am hoping to learn a lot from the forum. The two main things I'm about to tackle are rebuilding the water and generator bays. The check valve on the water fill had a slow leak that has rotted all the plywood out form under the water access bay. Since I need to tear part of it down to get to the check value I was thinking of just updating the whole thing and making it finished with stainless and doing what ever else I can to update it. I've seen the water bays on Liberty and Marathon and they look much more inviting and user friendly. I'm a pretty good handy man but I'm seeing stuff that is foreign to me like the connection called "Blow Out" but since it has an air compressor fitting on it I'm assuming that is for winterizing. The fittings underneath got dinged form a high center and leak from the black tank connection so another reason just to give this whole area an overhaul. I will need to replace the insulating foam on the underside also (what to use ?).
Can I get suggestions on what I should add (or eliminate) since I'll be redoing this ? A maserator ? A better water tank sensor (found this one https://www.watercounter.com ) . I'm thinking of ditching the filter that clean up the inbound water since I don't drink it anyway and making extra room and simplifying the bay. Are there any experts that have done this that I could PM and ask ? Thanks.
The generator bay has the sound material falling down and I figure since it's been 14 year since it's been out that it would be best to pull it and inspect the connections and see what else I might do to improve it while I'm at it like new air bags and possibly small air compressor to keep the air bags topped off. The plywood on the gen bay walls has some dust and oil residue so I was thinking of putting another layer of something (aluminum flashing, high density foam, more plywood ?) between the interior wall and the new thick foam. It would be great to know what parts others have used and recommend. What about adding any kind of fire suppression system while I'm at it and which is recommended ?
Thanks in advance for any input !
